Anadi_Mondal
Hello This should be added with previous post.
I have just read the topic ''24.7.4. Reporting of Current Positions for Unsteady Tracking'' from Ansys user guide and export a file "Time X-Position Y-Position Z-Position X-Velocity Y-Velocity Z-Velocity diameter temperature Particle Mass" . But I need (( x y z x-vel y-vel z-vel diameter temperature mass-flow-rate )) info at OUTLET(outlet flow condition) . How to get these variables at outlet?
Moreover , for injection file I need "mass flow"(kg/s) , but in the variable field I have 'particle mass'(kg). How to get flow rate? Will this flow rate I get from outlet or this is the flow rate I need to define during injection to get outlet profile?
Regards Anadi
