I ran the top surface down using a Displacement BC, without gravity, in order to plot the force-displacement graph.
It looks like you adjusted the mass of the supported object and the frame itself in order to put this mass on the flat portion of the force-displacement graph.
The deflection due to gravity is working as it should.
