Navya C
If you want to replicate only one leg of the coil, then create a region such that it is touching both the ends of the conductor.
Now change to face selection mode(click F on keyboard) select the face of the conductor on one side>right mouse click>assign excitation coil terminal.
On the pop-up window, define a number of conductors. and click ok.
Do the same on the other side. Make sure one side is current entering and another side is current leaving(use swap direction option).
Regards
Navya
