Seems to indicate issues with the MPI. Try to check your resource configuration, which MPI are you using? Is the simulation file stored on a local hard drive or a network drive? Try to 'Continue' the job/s that have stopped or 'Restart' if the sweep does not take too long to run. This should also run the sweeps below/after it.
