Extend the domain by at least 5-6 diameters in each direction. Your shocks are far too close to the boundary and using "no reverse" flow is causing you problems. Post process in Fluent too, you may need some of the data that's not moved to CFD Post by default.
If you look under courses at the top of the page you'll see some that are very relevant to this problem.
