August 13, 2021 at 1:35 pm
参见说明 https://support.lumerical.com/hc/en-us/articles/360034918833-Boundary-Conditions-in-CHARGE-Simulation-Object
APPLY AC SMALL SIGNAL: This option is valid only during small-signal ac simulations. The value is set to NONE by default. When enabled it applies a small signal AC voltage to the DC bias voltage.
- all: SSAC voltage will be applied to all bias points.
- last: SSAC voltage will only be applied to the last bias point.
