August 23, 2021 at 4:11 pm
Hi thanks for the response. The force I am trying to capture is the thrust produced. I wanted to simulate the propeller as if it were to be hovering stationary and see the thrust produced at varying RPM, I put my inlet velocity as 0. Was I correct in doing so or would I need to input a freestream velocity and if so what would be a good velocity to input ?
Thank you for your help
