Navya C
Hi @Kashish You need to define an outer band. You can create an outer cylinder and an inner cylinder(till the middle of the airgap) and subtract the inner cylinder from the outer cylinder. and assign a band for the remaining hallow cylinder.
You can use the machine tool kit from act extensions under the View tab.
Here is the procedure to activate the machine toolkit.
Once you are on Maxwell >View>ACT extensions
On the pop-up window select Manage extensions
In the next window, you will see various extensions.
Select the Machine toolkit to add it to the wizard.
Now go back and launch your wizardand fine Machine toolkit.
Please refer to Maxwell help documentation for further help on these topics.
Regards Navya
