August 31, 2021 at 9:56 pm
can I trust the deformation and stress results obtained from the inertia relief?
Yes.
Will I get the same deformation and stress results if I take the accelerations obtained from inertia relief and use it in a linear static structural analysis?
You can't run a static structural analysis on a model with no supports. If your model has supports, then you don't need inertia relief.
Is there a way to conduct Inertia relief ON and Large deflection ON analysis together (because that would save us time instead of re-conducting the analysis with Inertia relief OFF and Large deflection ON)?
See this discussion: https://forum.ansys.com/discussion/30842/how-can-i-do-non-linear-analysis-with-inertia-relief-turned-on-on-ansys
Yes.
