September 3, 2021 at 1:04 am
The default analysis setting for Static Structural has Large Deflection turned Off.
The default analysis setting for Transient Structural has Large Deflection turned On.
Change Static Structural to have Large Deflection On and solve that model to see how the result changes and if it is closer to matching the Transient Structural model.
If the results don't match, then run the Transient Structural model for a longer end time and make sure damping is used and the results should converge on the new Static Structural result.
