Bassemaa
It turned out that the nodal coordinate system matches the global by default.
I managed to solve the problem with NMODIF command to redefine the nodal coordinate system and rotate it to the beam angle, then point the RX solution to the solution coordinate system SOLU.
Thanks again!
