Guilin Sun
It is ok. I guess you know it is due to short simulation time. Usually you can set very long simulation time and use the autoshutoff min to terminate the simulation.
Maybe you just tried to do a simple test. for straight waveguide, or uniform material, no need to simulate long distance since the fields can be calculated analytically, either using mode property, or material property and the wave.
