Ram Gopisetti
you can use the cross plot option in LSPREPOST to plot the stress vs strain (v-m vs eps)these are true stress and strain and then use the reverse formula based on your specimen diameter and elongation to convert the plot to engineering strain and strain.
Check the following file as a reference for tensile testing .
you can also further smooth the graph.
cheers, Ram
