DmitriyTGU
Hi!
Thanks for your reply. This is what I am using.
#include "udf.h"
#include "sg_mphase.h"
#include "mem.h"
#include "sg_mem.h"
#include "math.h"
#include "flow.h"
#include "unsteady.h"
#include "metric.h"
DEFINE_SOURCE(heat_source, c, t, dS, eqn)
Thread *pri_th, *sec_th;
real source;
real x[ND_ND],volume,r,k;
volume = C_VOLUME(c,t);
C_CENTROID(x, c, t);// Acquire the cell centroid location
real T = C_T(c,t);
pri_th = THREAD_SUB_THREAD(t, 0);
sec_th = THREAD_SUB_THREAD(t, 1);
r=sqrt(pow(x[0],2.0)+pow(x[1]-0.002,2.0));
k=(pow((3.46/0.003),2.0)); // concentration factor
if(C_VOF(c,sec_th)>0.55 && C_VOF(c,sec_th)<1)
if (r<=0.0015)
source = (950*exp(-k*r*r));
dS[eqn] = 0.0;
else
source = 0.0;
dS[eqn] = 0.0;
else
source = 0.0;
dS[eqn] = 0.0;
return source;
Such a source does not generate heat.
2 Phase Mode is in use.
I also found that, before the material melts, X, Y momentum act on heating, even if they do not heat up to zero.
If you turn off X, Y momentum, turn off heating appears, but still this is not enough.
The question is, what am I doing wrong? I've spent a lot of time looking into this problem. Heating can be obtained if instead of 950 there will be about 1e10
