Erik Kostson
so when you start a new mechanical thermal-electric analysis, have only one Step as it is be default (do not go to analysis settings and set steps equal to 17), then go to the first row and second time column (there is only one row since we have one step only) and paste your column to the time column for the "End times".
Then create the current object and paste your values under the current column (choose the first row and second column for the paste).
All the best
Erik
