estat
Eric your recommendations on the static structural analysis with the membrane elements are working well!
However, the simulation converges with pressure rates 20 times lower than the ones it was ment to withstand.
When I try to use just a slightly higher pressure rate, I get this error: Element 6963 has excessive thickness change.
Any further suggestions ?
