October 17, 2021 at 7:37 pm
I downloaded your model and opened it up to look for problems.
1) I agree with Erik's suggestion to cut the domain in half again and use a coarser mesh. The current mesh has 577k nodes, which greatly increases solution time.
I didn't cut the geometry in half, but I did use a coarser mesh, the one shown below has 50k nodes and solves in 219 increments in 28 minutes on 3 cores. Note in particular in the Mesh Details, I set the Defeature Size to 0.2 mm, the Default element size was set to 1.0 mm. The reason the Defeature Size is so helpful is that the geometry has some small features that I expect are just geometry mistakes that should be cleaned up such as this:
2) Put all faces on the symmetry plane into a Symmetry BC. You only have one face.
3) In Engineering Data, the PDMS material model fit to the data is okay but the error grows after 0.05 strain.
