October 17, 2021 at 8:25 am
Hello sir @peteroznewman
Thanks and the meshing problem is solved as you mentioned but it is difficult with multi-body.
To understand the difference between share I used both
1) Share in structure
2) Share in workbench option
1) Will give contact in Mechanical WB and 2) is not showing contact in mechanical WB. I tried once and will check again today still writing ....
Thank you
Thank you
