satri
do i need to use brackets? I thought fluent will write the case in the folder path specified in the beginning.
I did use brackets earlier.
I was able to write the case if i do wc q1.cas
i could not find this wc command in your tui manual does this wc command write the case as well as data?
or should i write the data separately?
