Hi @
hanisadek
3D/2D model from RMXprt to Maxwell is created with the help of a background script.
So, the only dimensional parameters that you can control will be those you see in the properties window. Because any other manual changes or objects you create in maxwell will not be a part of the background script.
If you want to change any other parameters go back to RMXprt, do the changes and create the Maxwell model again.
Regards
Navya
