Hi @
KMoula30
The cause, which is the current in the coil is counterclockwise.
So, the effect will be in a clockwise direction.
If you are applying Right hand thumb rule, it will apply only to the coil, and its filed as the source current is flowing in the coil only.
Regards
Navya
