DoodlerD
Sean,
Thank you for the feedback. I repeated the analysis with the following settings:
I significantly reduced damping to 0.1% and time step to T/50 instead of T/20. The results remained unchanged. I suppose this occurs because the thick shaft does not generate a strong response due to high material damping.
