hsr200
Hi SD
I use Fluent beta feature manual and generate RGP table. (The name of chapter might be "Creating RGP Files")
I generate water RGP table, and change it's value.
In water table, there are tables like volume, specific heat, viscosity, thermal conductivity and so on.
Each table consist p-T relation.
I changed each table value. for example, In volume table,changed water's volume to JP-10's volume. and other tables did same like volume case.
I use text file format to change each contents.
Thanks
