Navya C
Hi @kajal8 You can refer to the below guide
If you still didn't get the results. Please provide the below details.
Which solver are you using?
What steps do you follow to set up the model?
What is your expected value and what is the result you got from the simulation?
Provide the details along with screenshots to investigate the problem correctly.
Please use the image option and not the Attachment option while sharing the screenshots.
Regards Navya
