The point of maximum deformation is going to be different from the point of maximum strain, which is what you began the discussion with and caused my confusion, but now I see what you want.
How much does the point of maximum deformation move about in the model as the parameters change? I suggest you split the plane into 4 quadrants and reconnect them with the Share button in SpaceClaim so you can get a vertex at the center which will be close to the point of maximum deformation and you can request stress at that node.
