November 22, 2021 at 5:48 am
Parameters can be also set as functions of the other parameters. These are called custom parameters.
In the parameter set window , on selecting the respective parameter, in 'Properties of Outline' in the 'Expression' you can define the thickness of the middle portion of the geometry as a dependent parameter to a new parameter of length of middle section (As the thickness varies with the length of middle section). It can be stated as equation with the new parameter as a variable.
The following links can be referred for some more insights-
Working with Parameters (ansys.com)
Expressions, Functions, Quantities, and Units (ansys.com)
Hope that helps!
Thanks Sahil
