Sahil Sura
As Ansys employees, we will not be able to download files. Can you please insert an image instead , so that we can be better at assisting you?
When selecting the high and low faces, please do verify the selection of shroud faces along with the base.
For visual expansion of mesh and the results, following resource may serve helpful regarding the same-
Reviewing Results for Cyclic Symmetry in a Static Structural or Static Acoustics Analysis (ansys.com)
Thanks Sahil
