Navya C
Hi @Francoo The wires that are running parallel for a single conductor in a turn are called strands. it is the number of wires per conductor
Number of parallel branches is the actual parallel paths, if any, in a winding (mostly used for motor windings). this does not represent the conductors running parallel in a single turn as used in your case.
In your case, you can leave it as one.
.Regards Navya
