OROI
Hi
So you mean "ET,MATID,CABLE280" ,is better? No need to add anything else in APDL commands?
Cable minimun bending stiffness is 28000 N/mm2 and maximum bending stiffness is 57000 N/mm2 if it is made by aluminium. If steel core ACSR then minmum 46000 N/mm2 and max 63000 N/mm2. Should i use minimum or maximun stiffness value in engineering data? What about other parameters in engineering data if make new material, what are minimum parameters for this kind of case?
