Baloch
Thanks Erik The post was really explaining what I am looking for but I have couple of question if you can give an idea. 1) since by python its easier to get a certain object and formulate arguments.. By APDL can we put if like loop for multiple conditions and how to access a certain value? for example deformation?
2) what is explain in the post I can insert a APDL command for all steps which means that after ever load step the APDL command will run in the solution. So if use such a command to only run my python script after each point but issue is can we execute a python script using APDL command?
And also there is no way to program the script which can run also during the solution?
