If you think you will get a faster solution using a GPU, you may find you can't use the GPU to accelerate the solution without having an HPC license. Even if you have an HPC license, you may find the solver won't use the GPU to accelerate the solution because the ANSYS doesn't talk to that specific GPU for computation while solving. Only certain GPU cards can be used for computational acceleration. Check the list of supported GPU accelerators for ANSYS 19.2
If you want the Quadro card to use as a Display Adapter only, for good dynamic rotation of 3D graphics, that card will be fine.
