Andrew Stankovich
If you want to try using scripting as a solution something like this might suit your needs.
#Prompt the user to define a save file
outputDialog=SaveFileDialog
outputDialog.Filter=”Datum Point File (*.csv)|*.csv”
outputDialog.Show
outputfile=outputDialog.FileName
#Get all the datum points in the current file
allDatumPoints=GetRootPart().GetDescendants[IDatumPoint]()
#Loop through all the points and save the x,y,z coordinates to file.
with open(outputfile,”w+”) as outFile:
for dPoint in list(allDatumPoints):
X=dPoint.Position.X
Y=dPoint.Position.Y
Z=dPoint.Position.Z
outFile.write(str(X)+”,”+str(Y)+”,”+str(Z)+”\n”)
This will write the files to a csv file that can be opened in excel.
