phanicmsf
I want to see effect of mechanical tensile load acting on the block after cooling from 1326 to 20 degrees.
A tensile load of 200 Mpa acts on the two faces.(In the Fig shown as compressive).
So can I use Kinematic mount BC as explained above ?
Or Should I use any other BCs?
Any suggestions about applying BC using Remote Displacement method in this case will be a great help to me.
