March 4, 2022 at 7:36 am
Unfortunately it still diverged after 1250 iterations due to the same too large Maximum CFL number in the EWF model...
Also, an error window reports floating point exception.
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 843571 cells
12509.8709e+043.2876e-012.0323e-018.0409e-015.1685e-061.0080e+147.2821e-01 81:51:45 18750
Reversed flow on 13370 faces (92.6% area) of pressure-outlet 12.
Reversed flow on 9653 faces (75.7% area) of pressure-outlet 13.
Reversed flow on 3668 faces (53.8% area) of pressure-outlet 14.
Stabilizing pressure coupled to enhance linear solver robustness.
Stabilizing pressure coupled using GMRES to enhance linear solver robustness.
Experiencing convergence difficulties - temporarily relaxing and trying again...
Divergence detected in AMG solver: pressure coupled sub-iteration: 1 residual - h: 3.091311e+33; u: 2.805212e+33; v: 1.333100e+32
sub-iteration: 2 residual - h: 3.091311e+33; u: 1.633315e+32; v: 2.900875e+31
sub-iteration: 3 residual - h: 2.871481e+27; u: 2.805212e+33; v: 1.333100e+32
sub-iteration: 4 residual - h: 2.871481e+27; u: 1.633315e+32; v: 2.900875e+31
sub-iteration: 5 residual - h: 2.871481e+27; u: 2.805212e+33; v: 1.333100e+32
sub-iteration: 6 residual - h: 2.871481e+27; u: 1.633315e+32; v: 2.900875e+31
sub-iteration: 7 residual - h: 2.871481e+27; u: 2.805212e+33; v: 1.333100e+32
sub-iteration: 8 residual - h: 2.871481e+27; u: 1.633315e+32; v: 2.900875e+31
sub-iteration: 9 residual - h: 2.871481e+27; u: 2.805212e+33; v: 1.333100e+32
sub-iteration: 10 residual - h: 2.871481e+27; u: 1.633315e+32; v: 2.900875e+31
Film time = 7.807621e-03 with timestep = 7.6e-11, (max_cfl: 1.894628e+15)
Maximum CFL reached. Reduce time step by factor of 2
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 840131 cells
Error at host: floating point exception
Error: floating point exception
Error Object: #f
Error Object: #f
