February 23, 2022 at 6:16 pm
I see an issue with your Intel MPI -env APPDATA settings. I think you copy pasted the instructions from this post. You set the APPDATA to "C:\Users\lyap\..." this is my user name. From the screenshot your 'local folder' should be "C:\Users\sutan\..." or you can use "C:\". Also, if you are only running on your local computer "localhost", try to run this with Microsoft MPI instead. You can also check the resource configuration for FDTD or HEAT and use the same resource configuration from FDTD or HEAT.
