In Engineering Data you can create a material and use Orthotropic Elasticity. That will allow the properties of wood to be different in along the grain, in the radial and transverse directions.
You can also define a stackup of layers of wood with different directions.
It will be easier to help you if you show the geometry of what you want to model and describe the layer thickness and the overall thickness of the part.
