Kishan Konannavar
Hello
One approach to try could be to split the domain in such a way that it allows you to chose the region/surface to add inflation layers. For example, if the domain is split into 3 regions, upstream of BOI, BOI region and downstream of BOI then you may control the meshing in these volumes.
Hope it helps
Regards
Kishan
