March 7, 2022 at 2:25 pm
you can simulate it , you may want to use the revolute joint with the initial velocity to the body to solve the problem. But for the SPH, i don't think you can add a joint you may want to position it at an angle and use initial velocity to that plate.
Cheers Ram
Cheers Ram
