Ingrid Machecler
Hello
The definition of the dZ range (which is used to explore the data base) is not large enough in your case. In the cable properties panel, search for the Negative dZ and Positive dZ range.
I suggest that you look at the Users' Manual, section 5.7.1. Cables and more particularly the Nonelinear Catenary section.
Kind regards Ingrid
