tumulpurwar
Thanks Peter
Just one more question:
I have big assembly of beams and shell elements.
As share topology not working with beam, I decided to put beams under one component with Topology as " None "
and shells under one component with topology as "Share"
In workbench mechanical my plan is using contacts for beam connection with shell and use Node Merge under mesh tab for beam to beam connection, while hiding all shell plates.
Will my procedure is correct for beam shell assembly??
