March 26, 2022 at 4:51 pm
Thank you for the answer, DPM extended summary gives the information I want, the problem is solved.
FateNumberElapsed Time (s)Injection, Index
MinMaxAvgStd DevMinMax
in Fluid53562312.000e-051.260e+005.335e-013.661e-01injection-2 94556617injection-2370
in Film157051811.420e-031.260e+006.756e-013.814e-01injection-1 94452125injection-1810
Trapped - Zone 11419234291.676e-031.259e+005.582e-020.000e+00injection-20injection-20
Trapped - Zone 1244861.622e-021.052e+005.842e-020.000e+00injection-00injection-00
Trapped - Zone 13214295.165e-031.256e+005.463e-020.000e+00injection-00injection-00
Net63010756
Injected+Inserted63010756
Injected62952640
Inserted58116
(*)- Mass Transfer Summary -(*)
FateMass (kg)
InitialFinalChange
in Fluid1.218e-031.218e-030.000e+00
in Film6.248e-036.248e-030.000e+00
Trapped - Zone 113.164e-023.164e-020.000e+00
Trapped - Zone 125.374e-075.374e-070.000e+00
Trapped - Zone 131.770e-061.770e-060.000e+00
Net3.911e-023.911e-020.000e+00
Injected3.911e-02
(*)- Energy Transfer Summary -(*)
FateEnergy (J)
InitialFinalChange
in Fluid4.383e+015.761e+011.378e+01
in Film2.248e+023.147e+028.993e+01
Trapped - Zone 111.138e+031.152e+031.383e+01
Trapped - Zone 121.933e-021.933e-02 -1.398e-06
Trapped - Zone 136.367e-026.385e-021.842e-04
Net1.407e+031.524e+031.175e+02
Injected1.407e+03
But I also encountered a strange problem as described below.
I used the following settings to get the statistics information of all on wall particles, then I used a Python script with Pandas to sum the particle mass, which gives me the result 0.001231 kg, which is different from the value given by the DPM extended summary, 0.00625kg, why is that?
Net63010756
Injected62952640
Inserted58116
FateMass (kg)
InitialFinalChange
Injected3.911e-02
FateEnergy (J)
InitialFinalChange
Injected1.407e+03
