Guilin Sun
以后发中文帖子请到中文论坛: Photonics - Chinese — Ansys Learning Forum
请参考这个帖子将问题描述清楚,你是像修改FDTD中光源的频率、“model”还是分析中的频率,还是INTERCONNECT里面的频率?
一般用setnamed,参见
Ansys Insight: 几个简单实用的脚本Script命令:用于设置
Ansys Insight: Lumerical脚本命令Script列表
可以用问号加setnamed了解某个物件里面所有的可设置变量名字,比如
?setnamed("source");
NA
additional delay
amplitude
angle
angle phi
angle theta
bandwidth
beam diameter
beam parameters
beam radius wz
center frequency
center wavelength
current index
direction
distance from focus
distance from waist
divergence angle
eliminate dc
eliminate discontinuities
enabled
fill lens
frequency
frequency dependent profile
frequency span
frequency start
frequency stop
injection axis
lens diameter
maximum convolution time window
name
number of field profile samples
number of plane waves
offset
optimize for short pulse
override global source settings
phase
plane wave type
polarization angle
pulse type
pulselength
set frequency
set maximum convolution time window
set time domain
set wavelength
source shape
type
use custom pupil function
use global source settings
use relative coordinates
use scalar approximation
use thin lens
waist radius w0
wavelength span
wavelength start
wavelength stop
x
x max
x min
x span
y
y max
y min
y span
z
z max
z min
z span
知道以后就可以设置,比如,在光源里是显示频率设置的情况下,
可以用
?setnamed("source","frequency start", 1e15);
如果在Wavelength情况下应该是不能设置频率,建议就用波长。
