April 14, 2022 at 9:02 am
Dear Ashish Khemka
In advance, thank you so much for your reply.
So, How can I find that rigid body easily in the results?
Could this warning be that problem?
*** WARNING ***CP =330.301TIME= 22:45:24
There is at least 1 small equation solver pivot term (e.g., at the UZ
degree of freedom of node 6225) which may indicate a numerically
unstable model.Please check your results carefully.
EQUIL ITER8 COMPLETED.NEW TRIANG MATRIX.MAX DOF INC=0.3016E-03
DISP CONVERGENCE VALUE=0.1703E-03CRITERION=0.5779E-02 <<< CONVERGED
LINE SEARCH PARAMETER =0.5646SCALED MAX DOF INC =0.1703E-03
THE CONTACT STATUS HAS CHANGED AT3CONTACT POINTS
FORCE CONVERGENCE VALUE=275.9CRITERION=223.4
EQUIL ITER9 COMPLETED.NEW TRIANG MATRIX.MAX DOF INC= -0.3010E-03
DISP CONVERGENCE VALUE=0.3010E-03CRITERION=0.5897E-02 <<< CONVERGED
LINE SEARCH PARAMETER =1.000SCALED MAX DOF INC = -0.3010E-03
THE CONTACT STATUS HAS CHANGED AT5CONTACT POINTS
FORCE CONVERGENCE VALUE=134.3CRITERION=455.8<<< CONVERGED
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION
Regards Unur
Regards Unur
