I indeed found a way of checking the maximum skewness of the surface cells after generating the volume mesh. In Fluent Meshing I used the command
`objects/summary yes`
and then chose the mesh object for which I wanted to know the maximum skewness.
Also, one can click with the mouse right button on "Face Zone Labels" in Outline View -> Mesh Objects ->
New Post - Reply To: Check surface cell maximum skewness after creating the volume mesh
