April 20, 2022 at 2:07 pm
thank you for your support.
I am simulating with tire model without rim. So I want rigid bodies instead of rim but I don't know how to set it up.
I'm using Couple Field Transient model as it can output temperature result.
I can make the tire move on the road surface, can make it rotate in place but cannot combine so that it can both turn and move forward.
I am placing load at center using remote point to create point and then apply a force on that point. Is that correct?
