May 14, 2022 at 4:41 pm
In the 2nd paper, Regarding the model, there is a slight change from the model of the paper. I think it may be due to not having the exact material that my problem is not correct. I can say that I haven't finished the simulation yet. So I'm trying with the 3rd paper.
In the 3rd article, they only need the tread, body ply, and Slide wall parts to serve the simulation(more clearly they cut the upper part).
This is the boundary condition part
And here are my settings.
Tread /road
Slide wall/Air
Tread/Air
Body Ply/cavity air
Liner/Rim
About the results, my simulation is wrong. I think it will have the most heat under the tread, not the side of the Slide wall.
Thank you so much for helping me.
Tread /road
