April 25, 2022 at 5:40 pm
An option would be to run using virtual display. Running the Lumerical scripts will require a CAD/GUI environment and a GUI license. Consult with IT/cluster admin if this would work on your cluster.
Note:This is not supported on all Linux installations and is provided as is without further support. When running a simulation using the script, the resource configuration settings in theLumerical product preference.inifile will be used to run the simulation. Ensure that you have the product preference.ini file on your local folder to run your simulation with virtual display.
