Forum Moderator
Because of the 2d-axi approach I'm not sure you can do this: you'll either have a uniform concentration or mass. If you have a sector then you will inject on every surface facet so other than some distortion due to inflation at the outer radius you should be OK. 30-60 degrees should be a good compromise between cell count and skew at the axis.
