April 29, 2022 at 8:29 am
hi Rob, thanks to your kind reply. So, what do you suggest? To keep the "scale flow rate by surface area"? Also I don't get your last sentence: what degrees are you referring to?
Moreover, I've realized that applying a "randomize starting point" and increasing the number of stream above 1000 allows to solve dpm concentration problems without using the "scale flow rate by surface area". Do you think this can be a good option?
