April 25, 2022 at 2:17 pm
Forum Moderator
Set the pressure outlet to have back flow "from adjacent cell", and review the backflow settings for turbulence: at present you may be bringing air in perpendicular to the boundary which will disturb the flow. Then see how the result looks. If the turbulence field is off you may be too diffusive due to excessive mixing.
